Posted by mkirsch on November 19, 2013 at 08:23:49 from (64.80.110.74):
In Reply to: Super MTA continued posted by Ellis Kinney on November 18, 2013 at 16:13:34:
IIRC, the drivetrain is in this order:
1. Engine flywheel
2. Clutch disk
3. Pressure plate
4. Transmission input shaft (driven from clutch disk)
5. IPTO drive tube gear (driven from pressure plate, must be lubed)
6. TA clutch mechanism (driven from input shaft, must be dry)
7. Rest of TA (must be lubed).
8. Rest of transmission (must be lubed).
This is why there are chambers. The IPTO gear needs lubrication, but the TA clutch MUST remain dry, and it's located in between the IPTO gear and the rest of the TA.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
