Re: cub front pully
Posted by Larry in WNY on November 19, 2013 at 09:46:42 from (12.145.221.230):
In Reply to: cub front pully posted by Brandon J on November 18, 2013 at 15:09:39:
I used a bearing separator from a Harbor Freight puller set and a large 2/3 jaw puller I got from Tractor Supply. A crescent wrench was used to keep the puller from moving. The 5/8"-13 bolt threaded into the crankshaft has a center drilled in the head for the puller bolt to seat into. I used some rubber from a bad tube as a washer to aid with twisting, but not sure it helped. Came off hard but didn't break.
Larry
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
