Re: A to B
Posted by mkirsch on November 19, 2013 at 11:22:41 from (64.80.110.75):
In Reply to: A to B posted by Phil Tibbetts on November 18, 2013 at 07:54:07:
More likely, the owner misidentified his tractor.
On an A, the engine is offset to the left, and is closer to the left rear tire than the right.
On a B or BN, the engine is CENTERED. It is the same distance to either the right or left rear tire. Only the driver sits offset.
There are some As with narrow fronts, but they are NOT factory. An A is too easy to tip over to the left with a narrow front, unless you set the left rear wheel very wide, or add duals.
