Re: Distributor shaft bushing
Posted by D Slater on November 19, 2013 at 16:40:15 from (184.14.177.226):
In Reply to: Distributor shaft bushing posted by kopeck on November 19, 2013 at 10:58:32:
Unless they quit furnishing the bushing its number 373577R91 at the dealer. Thinking the last time I checked around $40 to $50.
Most times you won't need to size the bushing after installation if you use a shaft .4910 diameter with a shoulder the same size as the bushing OD.
This post was edited by D Slater at 16:44:25 11/19/13.
