Re: 806 Fuel Shut-Off Solenoid Wire
Posted by The tractor vet on November 19, 2013 at 21:17:20 from (75.19.119.134):
In Reply to: Re: 806 Fuel Shut-Off Solenoid Wire posted by Absent Minded Farmer on November 19, 2013 at 20:09:25:
Ah No as you have light blue in 10 ga. a yellow in 14 ga. and orange in 14 ga. a black in 14 ga. and so on . yep i have rewired a bunch i have all the correct colors the dark greens the lite greens and purple the orange the lite blue and the dark blue the white and the red . The only wire i do not have is the resistor wire . Was never able to find that . so if and when i have to do something with that i revert back to the resistor up at the coil.
