Re: one way hydraulics on a 656
Posted by mkirsch on November 20, 2013 at 05:12:41 from (64.80.110.74):
In Reply to: one way hydraulics on a 656 posted by LJW on November 19, 2013 at 11:29:04:
Yup, on your 656, there should be a notch past "down" on your hydraulic remotes. That's "float" which is what you should use to lower a one-way cylinder.
It's ok to squeal the relief valve a little bit here and there, if you happen to pause in "down" by mistake, or need to make fine adjustments.
