Posted by rankrank1 on November 20, 2013 at 16:10:55 from (198.228.228.150):
In Reply to: H road gear problem posted by Old Popper on November 20, 2013 at 15:49:50:
I would start by pulling the shifter (only 3 bolts). If the ball end is worn weld up the ball end and reshape to the proper dimensions (there are pics and dimensions on this site).
I would also check the shifter for slop in that spring area. There is a even sloppy shifter kit on ebay for like $30 to $ 40 dollars since those ole Farmalls are so notorious for it. You can make you own remedy if its sloppy as well.
If your lucky correcting these 2 items will fix it.
If your not so lucky then you will have to dig deeper. FWIW 5th gear on a farmall h or m is not another matched gear set like gears 1-4 are . 5th simply sorta locks the 2 shafts to spin together which is why the shifter shifter lever travel is about half or less than it is for all the other gears (even when all parts are within specs). It was a very clever way from a manufacturing perspective to gain a 5th speed without adding the cost of another matched gear set. That said, that clever engagement system is more prone to wear than a matched gear set would be - especially if that tractor has had many years of hotrod shifting from 4th to 5th gear when moving which was often typical on an h as many will not take off from a dead stop in 5th gear.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
