Re: Distributor shaft bushing
Posted by Janicholson on November 20, 2013 at 16:26:40 from (74.60.94.18):
In Reply to: Re: Distributor shaft bushing posted by kopeck on November 20, 2013 at 11:29:17:
The electronic ignition systems have a required clearance between the sensor and the spinning trigger wheel. Some are close (.004") and some are greater. Use the net to determine what the spec is for the system you choose. At some level of wear, the rotor begins to touch the terminal points in the cap. When you check the real looseness of your shaft/bushing, be sure to measure in more than one orientation. Some wear egg shaped patterns. Points will not provide good accurate timing if the wear is more than .001" Jim
