Posted by John T on November 20, 2013 at 18:33:56 from (216.249.76.176):
In Reply to: Re: 200 Coil Question posted by gene bender on November 20, 2013 at 18:24:02:
That's right, a light gray oxide coating or oily film or carbon or pitting or burning or anything else that is a non conductor or too much resistance hinders current flow therefore no or low ammeter readings.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
