Re: Thanks to everyone who responded to my last post
Posted by rhtx55 on November 21, 2013 at 16:30:37 from (68.185.207.25):
In Reply to: Thanks to everyone who responded to my last post posted by Patrick HMD on November 21, 2013 at 13:41:06:
If you have no lights at all, then it is time to start eliminating the issues. Take a test light & install a six volt bulb. Make sure the battery is hooked up positive terminal on the battery to "ground" on the tractor frame. Take your test light and with the light switch off, check to see which side of the switch the power is on, ( which terminal lights up the test light) mark that terminal. Turn the light switch on and make sure you have power coming out of the switch to both wires for the lights. If not then disconnect one wire, and check that terminal on the switch for that wire on the back of the switch, if the terminal lights up the test light, you have power coming out of the switch but there is a short in that wiring circuit between the switch & the light(s) this wire goes to. Test each separately. When you get that far respond with your findings as this will get very lengthy to cover any and all possibilities.
