Posted by Brownie 450 on November 22, 2013 at 14:43:46 from (66.43.241.198):
In Reply to: 200 Coil Update posted by Lmack on November 22, 2013 at 09:39:28:
I have an old set of points [polished surfaces] & condenser out of a 6 & 12 volt system set up with jumper wires terminated with alligator clips for testing coils. By flicking the points open & closed, the coil high voltage can be estimated by the color of the spark---or lack thereof. Use the coil wire held 1/4 inch from the coil case to check output. Not fool proof, but tells if your coil is putting out or shot. Doesn't tell if troubles from heating the coil after a long run is what is causing trouble.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
