Re: F-20 Fenders Design Changes
Posted by rusticredacres on November 22, 2013 at 17:27:29 from (38.86.67.80):
In Reply to: F-20 Fenders Design Changes posted by bobinmi. on November 22, 2013 at 05:51:32:
Bob, To my knowledge and what I have saw on tractors is as follows. The 23063dx and 23064dx were the short sided fender for the steel wheel and would also work on the 28 inch round spoke tire tractors. Then the 33597dx and 33598dx is the taller sided fender for tractors with 36 inch cast center and 36 inch round spoke wheels. I have also got a set of shorter sided and narrow top panel set that I don't know for sure what they fit. All of these listed above have two braces. Then the Farmall Regular tractor had another fender 15551d and 15552d which is the same side panel height as the 23063dx and 23064dx but has a longer side and top panel that hangs down farther behind wheel and has three braces. As far as I have assumed this fender only fits the steel wheel or 28 inch round spoke tractors as they will not stand tall enough to clear 36 inch tire setup. I have pictures of all three if you wish I can send or post here. I have two sets of the 33597dx and 33598dx on F20 tractors and they clear 36 inch rubber fine.
