Re: Steering problems IH 574/2500A
Posted by JimB2 on November 22, 2013 at 18:15:32 from (99.240.243.222):
In Reply to: Steering problems IH 574/2500A posted by andyd4ntx on November 22, 2013 at 17:33:32:
Hi Andrew, if tractor has a 3pt, work the 3pt up
and down. Is the loader run off the main hydraulic
or off a pump driven by crankshaft? If the loader
is off the main hydraulic pump work the loader up
and down and the steering wheel left full then
right full.
Lift front end off the ground with loader and then
you can turn steering wheel easily. If tractor has
remote hydraulic outlets on the rear try pulling
the remote out lever until you hear hydraulic
relief valve buzz. Lever by your right heel below
3pt lever. If all else fails, look under the left
foot rest and the hydraulic filter is there on top
of the MCV valve.
On the bottom left of MCV valve there should be a
steel hydraulic line that feeds the power
steering.
With engine OFF and a clean bucket under the MCV
loosen the nut of the power steering line and
start engine and work steering wheel and watch for
leaking hydraulic fluid.
If the hydraulic fluid was milky, I would be
changing fluid and filter.
Good luck
JimB
