Re: Farmall H 6V Magneto Starting Problems
Posted by teddy52food on November 23, 2013 at 06:54:14 from (184.94.175.179):
In Reply to: Farmall H 6V Magneto Starting Problems posted by Brady Miller on November 22, 2013 at 18:34:56:
You have the plugs fouled by choking too much. Get new ones or burn off the old ones with a torch. When starting it cold, leave the switch off , close the choke & turn it over ONE compression. Then open the choke, turn the switch on with the throttle about 1/4 open & it should fire right up if you have a good hot spark. Never try to start it with the choke shut. If it runs OK after you get it started, chances are the mag is timed right.
