Re: Farmall H 6V Magneto Starting Problems
Posted by Janicholson on November 23, 2013 at 07:52:31 from (74.60.94.18):
In Reply to: Farmall H 6V Magneto Starting Problems posted by Brady Miller on November 22, 2013 at 18:34:56:
I agree with Teddy52food.
Plugs can and do get a conductive film on them that literally shorts them out. Pull them and place them on a non combustible surface. use a propane torch to heat the electrode end of each plug by heating each a little, then moving to the next. do this until each is very hot, but not glowing red. The threads will smoke and stuff will burn off of the electrodes. While they are warm, put them in and it will start. (use Teddy"s method to prime it up. The choke will, for sure, over fuel if used for more than 1/2 second of cranking, even with a kit in the carb. If the carb does not leak when it is sitting still with the fuel on, it is not the issue. Thedrain on the carb is intended to allow overflow and choke extra fuel to drip onto the ground. (it is a tractor built when this was OK!) Jim
