Re: Farmall H 6V Magneto Starting Problems
Posted by notjustair on November 23, 2013 at 11:14:24 from (174.250.176.11):
In Reply to: Farmall H 6V Magneto Starting Problems posted by Brady Miller on November 22, 2013 at 18:34:56:
My M runs everyday regardless of weather. Even when it is zero you use very little choke. Start cranking and then flutter the choke for just a second. When it starts it needs a little (maybe half) to stay running for the first 10 seconds then nothing. I don't even think about choke unless it is below 30.
Get the mag timed right, replace the plugs, and it should go. Do you have thick enough cables to get the wee volts you have to the starter? Everything has to be in top shape. It's all 70 years old now.
