Re: distributor guestion farmall M or MD
Posted by kentTTT on November 23, 2013 at 15:09:09 from (64.147.45.138):
In Reply to: Re: distributor guestion farmall M or MD posted by The tractor vet on November 23, 2013 at 13:57:56:
it has the advance weights and springs under the plate. I'm soaking it trying to get it loosened up. The rotor shaft is stuck will only turn with pliers.
