Re: distributor guestion farmall M or MD
Posted by D Slater on November 23, 2013 at 16:33:47 from (184.14.177.226):
In Reply to: distributor guestion farmall M or MD posted by kentTTT on November 23, 2013 at 13:32:21:
Hold the gear on the end of the distributor shaft with one hand and looking at the cap end. If you can turn the cam shaft clockwise and it springs back its for the gas. If you can turn counterclockwise and it springs back its for a diesel distributor with advance. That's if everything works as it should. Won't move far on the diesel one. Like TV said no advance on some diesels.
Also the original application can be identified if you can find the code. look on the OD where the two mounting clamps go for letters and numbers stamped in.
