Re: LED replacement bulbs?
Posted by Bob M on November 23, 2013 at 18:00:11 from (65.110.157.186):
In Reply to: Re: LED replacement bulbs? posted by Brian Schmidt on November 23, 2013 at 17:26:51:
AFIK the WD-9 is 12 volts from the factory. So converting to 12 volts will not be an issue.
However from the factory the was WD-9 positive ground. That WILL be an issue as most (all?) LED conversion lamps are neg ground.
Incidentally changing a generator-equipped tractor from positive to neg ground is not a big deal, and no new parts required.
