Re: 123 engine
Posted by GRAPE-DRANK on November 23, 2013 at 19:30:03 from (98.117.67.240):
In Reply to: 123 engine posted by olfebob on November 23, 2013 at 14:07:22:
I don't see why it wouldn't. BUT..... The water pump is completely different than the late Super A, 100/130. The rear of the block looks the same, the front of the block is different. Super A, 100 130. pulley is different than the 140 . The 140 has a different crank. The 140 crank has a thread on the end where the pulley is pressed and then a nut goes over it. A 140 crank can be used in a Super A/100/130 build, but a super A /100/130'crank can not be used for a 140 build.
I have no idea about clearance and sheet metal issues if using a 140 engine.
I know some are probably tired of reading this story from me, but I believe it is important to pass on. I have completely disassembled A Super A and a 140. Small differences like brakes, the thread on the torque tube of a 140 is bigger than a super A, the lift arms are different on a Super A vs a 140. The water pump assembly is totally different on a 140 and for the life of me I can't figure out why they changed it and what purpose it serves. I built an strong engine using a 130 block, Super A head and a 140 crank and cam.
I love the 140, but prefer the styling/parts availability of the Supers/100/130/200/230's.
If you're Super A is thermosiphen and you switch over to a 123 water pump find yourself a fuel tank like the 140 so you won't have a clearance problem.
This post was edited by GRAPE-DRANK at 19:40:10 11/23/13.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
