Re: Farmall M question
Posted by D Slater on November 24, 2013 at 12:06:39 from (184.14.177.226):
In Reply to: Farmall M question posted by JT on November 24, 2013 at 10:16:58:
FBK294226 and higher came with the disc brakes.
Hydraulic control rod probably wouldn't do you any good if a pipe is in the hole. Sounds like the pump and other parts are removed inside the liftall and the housing is just used for a reservoir. Most times when the liftall operating stuff is removed from the unit and pipe threads are added, the hole is used for the return line from a control valve or used as a oil fill opening. Tractor was built in feb. 52.
