Here is a case where I would hook a water manometer to the breather line to check crankcase pressure. You have to have a orfice hooked parallel to the gauge and I would use one specified for a 400 series diesel engine as no specs are available for old gasoline engines. May have to use a smaller orfice if you don't get at least a couple inch's of water reading. Then I would compare it to another similar engine, H, M or something close. If you have significantly more pressure you know you have excess blow by and need to tear it down. Breaking it in will be a waste of time in my opinion. They work good right out of the box or they don't.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
