Re: Farmall M question
Posted by Janicholson on November 24, 2013 at 17:18:55 from (74.60.94.18):
In Reply to: Re: Farmall M question posted by KEN IND on November 24, 2013 at 16:20:44:
If you have Osco-Lambert Discs (says this on the casting) you have limited resources to repair any broken parts other than having them made. The friction disks can be relined at a good brake and clutch shop. If you find no possibilities with these posibilities, the good thing is they can be replaced by the original band brakes (which are in my opinion much better than the IH or Osco disks. They are retro fitted onto only the Osco equipped tractors, not those equipped with IH produced disks, as the mounting holes for the band system are in the housing. I do not know if it is necessary to change the pinion shafts, but if so it becomes harder to retro fit the IH band as the bull gears will need to be moved to allow the pinion carriers to be removed. Jim
