Re: new to farmall need help with H
Posted by Oregon Tractor Jack on November 24, 2013 at 17:27:15 from (50.137.47.135):
In Reply to: new to farmall need help with H posted by gary in neb. on November 24, 2013 at 17:15:10:
The coupler is threaded on to the shaft. I believe needs to rotate counter clock wise as you look at it. It is not a reverse thread. I had to make a large "screw driver" out of a piece of flat bar to break it loose. It's been on there for quite a few years and could take a bit work to get it off. Good luck.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
