Jim, this is how my starter switch mounts. The non grounding cable (-) of the battery connects to one of it's lugs. The other lug receives the cable going to the starter motor, and the lead wire going to the ammeter. Is this correct?
Now, I clipped the test light end to the grounding side (+) of the battery, then touched the opposite side (-) of the battery and the light shined.
Next, with the testlight still clipped to the grounding side, I touched both ends of the cable that goes from the starter motor to the starter switch lug, and no light at either end. It didn't mater whether I touched the metal ends of the cable, threaded post, or nut.
Next i touched the ring end of the lead wire going to the ammeter, and no light again. Did I do all this correctly? All the mating points are clean.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
