Re: Poor PTO!
Posted by Ace Schrunk on December 08, 2000 at 20:09:19 from (205.188.193.57):
In Reply to: Poor PTO! posted by PLOWBOY on December 08, 2000 at 18:35:48:
You don't need shims, most likly the PTO coupling that engages the PTO is warn enough that it slide out of gear under load. Need to pull it out and see if that is the case
Post A Followup
: Re: Re: Poor PTO!
