Re: BN, water in oil...whits end
Posted by kopeck on November 25, 2013 at 10:08:41 from (169.244.176.2):
In Reply to: BN, water in oil...whits end posted by kopeck on November 25, 2013 at 08:04:56:
I know about those seals, that what I suspected when I tried the BARS stop leak. I premixed it so it would hopefully find the problems before it settled out.
I have to admit when I replaced the head gasket I didn't find anything that was obviously wrong with it.
I'm at tricky spot with this machine. I use it pretty often for chores so I hate to loose it. It runs well but needs plenty of attention, the front main seal leaks badly and it does use some oil. If I open up the engine to replace the sleeve seals I would be tempted to go much further since it really needs the attention.
I did check the compression, 90 on 3 holes and a hair over 85 on the the other one. It's still making decent compression.
If only money and time were limitless....
K
