Re: starter for a 300U
Posted by D Slater on November 25, 2013 at 20:20:25 from (184.14.177.226):
In Reply to: starter for a 300U posted by charlie M on November 25, 2013 at 16:59:09:
They used a different starter number. Due to clearance on the utility the drive housings were different and I can't remember if the starter housing was also different. Farmall and international starter switch and starter terminal ended up at a different angles.
Delco Remy number for a 6 volt utility was 1108041.
