Re: Super A runs dry on hill.
Posted by mkirsch on November 26, 2013 at 07:37:21 from (65.199.189.6):
In Reply to: Super A runs dry on hill. posted by CGID on November 26, 2013 at 07:15:10:
Really the only practical solution to that problem is to keep more gas in the tank.
If you're that low that going up a hill causes you to run out of gas and stall, the amount of fuel in the tank can be easily measured in CUPS, not gallons. There's just not much left and you're only minutes away from not being able to run on level ground, either.
