Re: Super A runs dry on hill.
Posted by Janicholson on November 26, 2013 at 08:08:01 from (199.17.6.160):
In Reply to: Super A runs dry on hill. posted by CGID on November 26, 2013 at 07:15:10:
Purchase a sediment bowl and valve assembly for a Distillate tractor (it has two outlet valves and threaded fittings)
Purchase a nice round lawnmower tank and make a bracket to allow easy mount and removal of the tank.
Use a barbed fitting and fuel injection rated fuel line to connect the tank to the sediment bowl.
Fill the small tank with gasoline.
Switch them when putting the tractor away to get it up the hill!
Then switch back to the main tank when parked, and remove the auxillary tank to empty into your car or other unit.
It seems complex, but it will for sure work.
You could get a distillate hood and tank and valve to use, but they are less portable, and more expensive. Jim
