Re: Super A runs dry on hill.
Posted by mkirsch on November 26, 2013 at 10:10:31 from (65.199.189.6):
In Reply to: Super A runs dry on hill. posted by CGID on November 26, 2013 at 07:15:10:
I thought of a solution:
NASCAR crews put extra-long fuel lines in their cars that hold a gallon of gasoline to extend their range in races.
All you need is a longer fuel line to get you up the hill. Make a coil out of several feet of 5/16" steel line to fit up under the fuel tank.
Really, the problem is easily solved by a simple change in behavior. There is no valid reason that it can't be done this way.
