300U power,steering
Posted by Bill(soh) on November 26, 2013 at 12:09:15 from (162.213.226.243):
I am working on a 300 utility that power steering doesn"t work. In trouble shooting this problem, I found very low oil pressure to steering gear. IT manual says to replace aux relief valve spring. Only problem I have is what do you replace the nla 365347r1 seal? In the drawing, it looks like it is made to hold the ball in place, but from the outside it looks similar to a freeze plug. Any ideas on how to seal the relief valve once that plug is removed?
Today's Featured Article - 12-Volt Conversions for 4-Cylinder Ford 2000 & 4000 Tractors - by Tommy Duvall. After two summers of having to park my old 1964 model 4000 gas 4 cyl. on a hill just in case the 6 volt system, for whatever reason, would not crank her, I decided to try the 12 volt conversion. After some research of convert or not, I decided to go ahead, the main reason being that this tractor was a working tractor, not a show tractor (yet). I did keep everything I replaced for the day I do want to restore her to showroom condition. ... [Read Article]
