Posted by Janicholson on November 26, 2013 at 20:40:44 from (74.60.94.18):
In Reply to: 560 diesel clutch posted by ziemerj on November 26, 2013 at 20:11:08:
THe Ceramic puck disk will take material off of both the flywheel and pressure plate as it is much harder than either. An organic (does not mean the edible sense of organic) compound semi-metallic disk (usually with copper strands in it) will last very well and be far less prone to expensive flywheel wear. In addition the organic disk will be softer on clutch engagement, chattering less and being less jerky when at the friction point letting it out. sense it had the ceramic disk, make sure the Flywheel is true, and the step depth is correct between the PP mounting surface, and the friction surface. Jim
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
