Re: Another bent drawbar ?
Posted by DeltaRed on November 27, 2013 at 08:24:39 from (65.100.146.165):
In Reply to: Another bent drawbar ? posted by Al L. in Wisc. on November 27, 2013 at 08:17:07:
No heat.Set it in a press and push.Use your handyman
jack and suck it together(rotate the top part so to
make it into a 'clamp' of sorts);use a large 'come-
a-long' puller or similar
