Posted by notjustair on November 27, 2013 at 10:32:05 from (174.230.128.83):
In Reply to: Super C starter posted by ffinmich on November 27, 2013 at 09:12:57:
She's gummed up. My M does that in the winter. After it runs a bit and heats things up the old goo on the shaft loosns up and lets her work right. Mine isn't bad enough to pull - if it does it I stop and crank again and it works.
Pull the starter and spray the gear end with brake cleaner and clean it good. Then spray a little chain lube on it and put it back in. Make sure there is full amperage getting to the starter. If it is just barely spinning it will not kick the gear out. Then you jut have a weak electric motor spinning. I've also used the torch to heat up the goo and cleaned it off.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
