Re: cutout on Farmall H
Posted by Bob M on November 27, 2013 at 10:56:04 from (69.207.87.35):
In Reply to: cutout on Farmall H posted by charlespretzer on November 27, 2013 at 09:45:13:
Charles - Take the cover off and peek inside the CO/VR. If only a single relay inside it's a cutout; 2 relays makes it voltage regulator.
Or count the terminals: 3 terminals (ARM, BAT and FLD) is a cutout; 4 terminals (adds an "L" terminal) makes it a voltage regulator.
To diagnose the problem I can highly recommend John T's troubleshooting procedure (link)!
