Re: m farmall grader
Posted by old on November 27, 2013 at 20:42:42 from (209.86.226.57):
In Reply to: Re: m farmall grader posted by Bob M on November 27, 2013 at 18:51:45:
The A/C WD45 was not used but the WC was and it was made by A/C not an aftermarket like used in the M Farmall see picture above. A/C did make one that used the WD45 engine but was not based on the WD45 tractor. The W Speed Patrol was based on the WC tractor but had an extended front put on and the blade assembly
