Posted by Stumpy(NH) on November 28, 2013 at 16:00:14 from (71.169.175.116):
In Reply to: Super H Missing posted by DV on November 27, 2013 at 17:27:14:
Just another angle on the problem. I have an Oliver Super 55 that did exactly the same thing. I found it to be number 4 exhaust valve sticking lightly.
Try finding which cylinder is missing at idle by removing and replacing the plug wires until you find the cylinder. Remove the valve cover. While the tractor is running place the blade of a large flat screw driver in the coil of the valve spring to add tension. If the engine stops skipping, you have found your culprit. It most likely will not be an intake valve or it would be backfiring through the carb.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
