Re: Super C wiring
Posted by Janicholson on November 28, 2013 at 20:37:50 from (74.60.94.18):
In Reply to: Re: Super C wiring posted by Janicholson on November 28, 2013 at 20:32:23:
To set it up negative ground, put the battery in with negative ground. Do not stert it. Use a piece of #10 wire (solid wire copper with vinyl insulation is good) to jump across the regulator from Bat to Arm terminals. You will need to reverse the wiring on the amp meter as the meter will read backwards if you do not. Jim
