Re: Farmall h wide front
Posted by Paulginmn on November 29, 2013 at 14:38:30 from (68.169.209.237):
In Reply to: Farmall h wide front posted by 1949farmallH on November 27, 2013 at 19:36:35:
the wide front under my H was from a M I took the big plate off and milled down the side to make it narrower. I have seen someone good with a torch use a straight edge and cut the sides as well. I also set up the part that bolts to the boaster in the mill and slotted the 2 holes to make it fit. My part was all welded up so wasn't to worried about wreeking a good one.
