Re: Super H wiring
Posted by Janicholson on November 29, 2013 at 15:11:00 from (74.60.94.18):
In Reply to: Super H wiring posted by burnt-smta on November 29, 2013 at 14:42:41:
You need either a diode in the wire going to #1 terminal, or a 10 ohm resistor, or a marker lamp (Bulb not Diode). This will feed the #1 terminal with ignition voltage from the switch side of the ballast resistor. and prevent discharge. The #2 terminal wire should go to either the battery+ at the starter switch, or the big terminal right there at the alternator (short wire). Jim
