Re: oil coming from breather
Posted by 300jk on November 30, 2013 at 12:56:21 from (174.252.49.16):
In Reply to: Re: oil coming from breather posted by rhtx55 on November 30, 2013 at 11:42:05:
Hey rhtx55 the tube I have doesn't come out of the head
but runs from the top of the valve cover to the stack on the
air cleaner ! So I understand you correctly if air enters the
crankcase through the blow by tube near the distributor
and vents through the line that goes from the valve cover to
the air cleaner stack right ? I thought it was just the
opposite and the excess was pushed out the breather tube !
Besides blocked passages is there anything I should look for
before i put that right side inspection cover back on ?
There is a little sludge but nothing looks plugged ! I
appreciate any advice !
