Not stock but this works for me I broke them bolts before I take a 12 ga. metal about two inches wide x the with of the radiator plus about two inches put a one inch bend on both ends of the metal. Cut the head off of a bolt that fits the mount holes on the tractor then drill one hole in the center of the "cuff." Weld the bolt to cuff then add a little rubber cushion. the cuff keeps radiator from sliding to and from the fan the upper mounts keeps it from sliding side to side
Today's Featured Article - New Hitches For Your Old Tractor - by Chris Pratt. For this article, we are going to make the irrational and unlikely assumption that you purchased an older tractor that is in tip top shape and needs no immediate repairs other than an oil change and a good bath. To the newcomer planning to restore the machine, this means you have everything you need for the moment (something to sit in the shop and just look at for awhile while you read the books). To the newcomer that wants to get out and use the machine for field work, you may have already hit a major roadblock. That is the dreaded "proprietary hitch". With the exception of the
... [Read Article]
Latest Ad:
[More Ads]
