farmall h 6 or 12 v
Posted by gary in neb. on November 30, 2013 at 16:55:32 from (199.193.213.140):
so i got the rear end and trans back together on my h and was going to work on the wiring. need to rewire it. noticed the genny has a cutout switch on the top and not a regulator so got to checking on the genny and it"s a 6 volt. i jump 12 volt to the "F" terminal and it turned over (genny off tractor) and on the "gen" side it really spun over. so the genny is good. BUT with a cutoff switch it wont charge will it? dont i need a regulator on it? or should i just convert it to 12 volt. had a 12 volt battery in it (dead of cource but i heard it run). so is the starter 6 also and if you convert do you need to convert the starter?
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
