Yes, the tube that hooks into the valve cover & connects to the air cleaner is the vacuum side. When the crankcase pressure becomes higher than what this tube can take care of, the path of least resistance will be the lower blow by tube, and it exists there. Since it was plugged with sludge, I am hoping the upper tube on the valve cover may also be plugged.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
