is it merely a bias resistor between field and ground? if so.. that's common. keeps some field current going on an A circuit reg when field contactgs pop open.
if it's a series resistor in line withthe field tab.. methionks that is a 1 size fits all a circuit reg, adn it's bials resistor is of too low a value and they are adding in some series resistance.
if that is so. play with it a bit. if you have some low value power resistors.. substitute them and experement.. see what you get.
keep in mind with field contacts colsed.. bias resistors between feild and ground are bypassed.. but anything in series with the genny field and the reg will not be bypassed.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
