Re: voltage regulator wiring
Posted by Janicholson on November 30, 2013 at 19:02:57 from (74.60.94.18):
In Reply to: voltage regulator wiring posted by pkat7658 on November 30, 2013 at 18:53:37:
The F terminal hooks to the "F" terminal of the generator.
The B terminal hooks to the amp gauge, on the side not connected to the starter switch, with a #10 wire.
The L hooks to the fuse input terminal for the light circuit. (10 gauge is also good)
The No name goes to the "A" terminal on the gen.
Jim
