Re: 900+ cubic inch Farmall M motor
Posted by Harold H on December 09, 2000 at 14:13:31 from (207.244.55.5):
In Reply to: 900+ cubic inch Farmall M motor posted by J. D. on December 09, 2000 at 12:28:36:
Since you are looking for so many cubic inches for your M, why not put the engine from a old International TD 24 in your M, then you would have 1090.6 cubic inches without modifing the engine. You would probably have to get some heavy duty front tires to hold the extra weight (the engine alone only weighs about 5675 lbs) and extend the hood just a little bit. It might be simplier to just remove the tracks from the TD 24 and put M wheels and hood on the TD 24. Better use 8 ply tires since it only weighs 38,740 pounds and you don't want to have a blow out.
Harold H
Post A Followup
: Re: Re: 900+ cubic inch Farmall M motor
