Re: Super M vs. 450 Flywheel
Posted by Centex Farmall on December 01, 2013 at 09:33:56 from (72.105.162.207):
In Reply to: Re: Super M vs. 450 Flywheel posted by D Slater on December 01, 2013 at 05:18:20:
Thanks. I was asked this question but I have not had a 450 that far apart...yet.
I have another question if you catch this reply: Is the input shaft and counter gear the same on a 400 and 450 (both with TA)?
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
