Re: cub guys carb help needed
Posted by rustyfarmall on December 01, 2013 at 13:27:15 from (208.126.186.41):
In Reply to: cub guys carb help needed posted by ericlb on December 01, 2013 at 10:43:23:
I think those original Cub carburetors had an issue with the top becoming warped, and then the 2 halves will not mate correctly, and of course the gasket won't seal up either. Only other thing I can think of is that maybe the float height is not correct, or the float has a pinhole and WON'T float, or maybe the float valve is still sticking. You DID clean that new valve and seat with carb cleaner before installing?
